Gbodyparts.com has themWhat's the story on those lower door panels. Is that how they come ,with the carpet and color or is that something you did ?
Also where did you get them from, they seem nicer than the ones I have seen in the past.
Wow impressive you can run that much timing with 10 to 1, what are the can specs? Maybe the Edelbrock's better chamber make a big difference too. I pinged on 91 with 9.5 compression and the 204/214 cam in my Olds 350, unless everything was just right, cold plugs, slow curve and limited vacuum advance.
Are you going to use the 5.25" speakers or (slightly trim) for the 6.5" ? On the 6x9 are you using the adaptors or modifying the package tray ? Keep us updated on the install .http://www.gbodyparts.com/product_info.php?cPath=55_84_89&products_id=791
You choose your color. The carpeting is not attached, just laying on there for the pic. And it doesn't look like the panels attach exactly as the factory ones so we will see how great they are after I get them installed? Initial impressions are that the way that speaker mount cone is molded on the door panel, it adds quite a bit of structural integrity to hopefully "solidly" mount the speaker but again we will see if rattling problems persist after the installation? I am sure I can fab some metal reinforcement if they do but naturally would prefer to not do that.
Since my entire interior is gutted at the moment adding Dynamat, battery relocation, and installing the Sub, Amps, and 6x9s in back along with the new head unit, all the wiring, this may take a couple of weeks . . .
or years it seems!
Sounds like a good idea on your speaker ideas, ive had the same thought on the 6x9 s . I dont know to much about the the dual batterys , but if the cca are good enough , i dont see why it wouldn't work, and the extra weight above each tire would be goodSo, what do you think of this idea? I was already going to build 3 sided boxes on either side of my sub . . .
. . . to neatly attach all the wiring for the battery boxes [yes 2], amps [again 2], plus the powered sub, etc. So picture a carpeted flip down cover on either side of this sub that neatly hides everything. Anyway, since these 4x10 to 6x9 mounting converters are a kluge at best, I thought why not just make it 4 sided and mount my 6x9s directly under the 4x10 holes on the roof of the boxes? After getting these speaker converters, I was ready to just cut 6x9 holes in my rear deck [and I still might] but I got to thinking this might be the next best thing and no deck holes required.
For anyone that cares, I am going to use [2] deep cycle AGMs . . . the same batteries I also use on my solar array here. They are only 24 lbs, are quite a bit physically smaller, but just qty 1 are down a little on CCA. But I get deep cycle and [2X] the Ah for the times I'm running my soon to be 850W sound system for extended periods and even for times my lupus gets me stuck in bed for several months and I get out to find just the trickle bleed from the ECM and electronics and that damn clock have caused yet another dead battery. Over the last 10 years, since dead conventional batteries don't like being dead for extended periods, I bet I've gotten pro-rated waranty replacements 4 times. And, I've taken the battery weight out of the front and will instead have 24 lbs. over each rear tire instead of 40-45 lbs of conventional battery on just one side.
Make sense? Just e-thinking out loud I guess . . .
