The only difference with big block, and small block Oldsmobile V8 motors, is deck height.... with BBO having a higher deck. Almost all the parts are interchangeable bolt-ons, with some of the parts requiring some modifications to fit like cranks and heads. All Olds heads are interchangeable...260ci up to 455ci. Many mistakenly call the 403 a big block, and the 350 "Rocket", or 350 "Gold Block", a big block... all small blocks. The 403 uses 1/2" head bolts, and the big block have 7/16" head bolts, so the BBO heads need to be drilled out to 1/2" to be bolted to the newer blocks... along with the port-matching on the intake. So, because the deck height is higher on a big block Olds, the BBO intake is wider, so it won't fit a SBO. Everything else is pretty much interchangeable!
thank you....
