If the EGR is not opening at cruise you would not notice anything, if you floor it then your valve might ping caused by the increase temperature of the combustion chamber since the EGR is not allowing the burnt exhaust to cool down the combustion chamber. If the EGR is stuck open your will have a rough idle. When the engine is cool you can put your finger under the EGR and push the valve open to see if it is stuck.
For the cam timing I'm saying if the chain is stretched the effect will not change with RPM.
For the accelerator pump it's easy to check with the air cleaner removed. As you go to WOT there should be gas being sprayed into the carb consistently.
Have your checked the in and out temperature of your catalytic converter to see if it is plugged and affecting the car's performance. That could be coming apart inside and rattling
