Hello all. I have been doing quite a bit of work on my wagon lately and recently it started running very poorly. Here are the symptoms. On WOT the car seems to run like normal, but cruising it starts surging and momentarily losing power. It has hesitation off the line and starts hesitating even with steady throttle. I hear popping sounds while driving and a rattling sound as well...
The car is all factory including all the smog equipment (I live in CA), new air pump, professionally rebuilt factory carb and new gasket, new fuel pump/filter. No CEL's and all the ignition stuff is in good condition.
I have gone over the vacuum hoses twice over and have replaced all bad hose. The carb is also correctly fastened. I am sure it is not a fuel issue because during a trip over a mountain (literally) it runs normal under long WOT stints, which also makes me think it is not ignition related but I checked the plugs and everything looked fine.
When I first got the car I did pull the EGR and clean it up and reinstall it. However the rattling is making me think this is the culprit. Does this sound like I am on the right track?
I manually moved the EFE valve and it doesn't appear stuck.
