Wait- you left them off the carb or you mean you left them alone? The float level might be correct but the float may be sinking and causing the flooding. Did you use a new float? The proper fuel level should be no where near that solenoid gasket, it should be below it. The seal is only there in case of sloshing fuel- not designed to be flooded with fuel. I think a bad float was the culprit here.but didn't replace the mixture control solenoid or the throttle position sensor.
Really, a Dualjet? I thought everything other than the 3.8 in G bodies were either EFI or E4M series Qjet, even in Canada in 1986.
yep thats what i thought. but it is a dauljetQjet, see his pic in post #3.
