This afternoon I started the "simple" task of replacing the water pump on my 3.8...after removing the 4 nuts holding the fan on, the fan would not move at all. After a lot a hammering and prying and finally cutting the studs between the fan mounting plate and the pulley with a hack-saw the fan was still not coming off. So I took the hammer to it again and the water pump shaft ended up snapping. :x
Has anyone ever encountered a water pump shaft seizing in the fan?
It ended up being a 4 hour water pump change. :x
