Amazon knows more than Edlebrock cause research, research, research. If 1901 & 1902 are Qjets type carbs GM, Edlebrock & Holley have it wrong on what's a square bore or a QJet which in turn makes all of use passing usable info wrong about what type of carb we are using. Research the manufactures web sites not sellers web sites.
Don't like this posting, don't respond to my posting, don't acknowledge this or me for posting this. Research. research, research.
The Edelbrock #1901 AV2 Series 500 cfm Carburetor is designed and calibrated for small cubic-inch single carb applications, match with an Edelbrock Performer or Performer EPS manifold or other brands of similar design.
www.edelbrock.com
AVS2 Carburetor #1901 500 CFM With Electric Choke, Satin Finish (Non-EGR)
$479.95
Starting at $44/mo with Affirm.
Prequalify now
Add to Wish List
OUT OF STOCK
SKU
1901
DETAILS
The Edelbrock #1901 AV2 Series 500 cfm Carburetor is designed and calibrated for small cubic-inch single carb applications, match with an Edelbrock Performer or Performer EPS manifold or other brands of similar design. Includes both timed and full vacuum ports for ignition advance. #1901 is calibrated for single-quad applications and factory equipped with: Metering Jets - Primary .095, Secondary .095, Primary Rod .070 x .052, orange spring (5' Hg). Use carb Studs #8008 or #8024 if needed. Match with an Edelbrock intake manifold for the ultimate induction upgrade.
DOCUMENTS & INSTALLATION NOTES
PDF-Installation Instructions
SPECS
Manufacturer | Edelbrock |
Application | Universal |
UPC | 00085347019014 |
Recommended Use | For Single Carb Applications |
Series | AVS2 |
Condition | New |
Metering Rod Size | .070 x .052 in |
Gasket Or Seal Included | Yes |
Barrel Quantity | 4 Barrel |
Flange Type | Square |
Secondary Jet Diameter | 0.095 |
Main Venturi Diameter | 1.19 |
Body Height | 3.25 |
Bore Diameter | Primary Bore 1.44; Secondary Bore 1.6875 |
Spring Force | 5" Hg (Orange) |
Availability Note | Available to Order |
Warranty | 12 Months |
Emissions Code | https://www.edelbrock.com/emissions-guide/ |
Hazardous Materials Warning | WARNING: This product can expose you to Zinc, which is known to the State of California to cause cancer or birth defects or other reproductive harm. For more information, visit www.P65warnings.ca.gov. |
Installation Notes |
- Thunder Series AVS2 Carbs will work with Ford automatic overdrive trans (AOD) when used with Lokar bracket SRK-4000; Edelbrock carburetors are not calibrated for or compatible with alcohol, race or E85 pump fuel. The use of alcohol or E85 in your Edelbrock carburetor will damage your carburetor and void your warranty.; The use of a new fuel filter between the fuel pump and carburetor is required. Failure to do so will void the manufacturer's warranty of the carburetor; You must use Edelbrock Adapter #2732 when installing a Performer Series carburetor on certain Edelbrock intake manifolds
Choke Type | Electric |
Finish | Satin |
Material | Aluminum |
CFM Rating | 500 cfm |
Primary Jet Diameter | 0.095 |
The Edelbrock #1902 AV2 Series 500 cfm Carburetor is designed and calibrated for small cubic-inch single carb applications, match with an Edelbrock Performer or Performer EPS manifold or other brands of similar design.
www.edelbrock.com
AVS2 Carburetor #1902 500 CFM With Manual Choke, Satin Finish (Non-EGR)
OUT OF STOCK
SKU
1902
DETAILS
The Edelbrock #1902 AV2 Series 500 cfm Carburetor is designed and calibrated for small cubic-inch single carb applications, match with an Edelbrock Performer or Performer EPS manifold or other brands of similar design. Includes both timed and full vacuum ports for ignition advance. #1902 is calibrated for single-quad applications and factory equipped with: Metering Jets - Primary .095, Secondary .095, Primary Rod .070 x .052, orange spring (5' Hg). Use carb Studs #8008 or #8024 if needed. Match with an Edelbrock intake manifold for the ultimate induction upgrade.
SPECS
UPC | 00085347019021 |
Series | AVS2 |
Condition | New |
- Manual Choke; Manual choke AVS2 Carbs cannot be converted to electric choke; Thunder Series AVS2 Carbs will work with Ford automatic overdrive trans (AOD) when used with Lokar bracket SRK-4000; Edelbrock carburetors are not calibrated for or compatible with alcohol, race or E85 pump fuel. The use of alcohol or E85 in your Edelbrock carburetor will damage your carburetor and void your warranty.; The use of a new fuel filter between the fuel pump and carburetor is required. Failure to do so will void the manufacturer's warranty of the carburetor; You must use Edelbrock Adapter #2732 when installing a Performer Series carburetor on certain Edelbrock intake manifolds
Choke Type | Manual |
Finish | Satin |
