Core Support Bushing Questions
6,826
6,730
Can someone tell me why I have to shim my core support upwards about 1" to get everything to line up?
New body bushings. New core support bushings.
Idc one way or the other I just want to know why.
  • Wow
2 hockey pucks work perfect.
20,391
how many shims were there when you took it apart and have you kinda got the new core bushings in correctly... :popcorn:
7,987
18,693
Where did the core support bushings come from?
6,826
6,730
Bushings are stacked as follows
Frame
Large bushing
Core support
Small bushing
Bushings are from mikes
There were no shims or anything of the sort beforehand with the old bushings.
carnutjw
624
1,469
Core support was too low? or too high from the frame? Where is the frame supported? When I did my body bushings (with drivetrain still in), the front frame section would droop quite a bit if not supported ahead of the engine
  • Useful
PBGBodyFan
792
1,223
Wisconsin
I’m just here to say the same thing. If the front end is off the ground it likely is making a gap for you. Put the wheels or weight on the front suspension to get it to ride height to get the proper gap. Lots of sag in the frame with front end weight.
6,826
6,730
Car is on the ground on wheels. Has been for a month or so. Door gaps are the same. Body is firmly bolted down.
20,391
are you sure there was no shims when you took out the core bushings...this is kinda the way it came from factory on a Monte Carlo.... :popcorn:
