crossmember bolts
if you're are going to use a polyurethane transmission bushing you'll need to upgrade your engine mount bushings to polyurethane as well....the three have to be made with the same material
I'm using solid motor mounts. I was thinking of using a poly trans mount, but you're saying all three have to be of the same material? Aware me on that please.
if your using solid mounts then you need to run solid mounts in each location or you'll break something...the three mounts need to be the same
from competition engineering....
Solid Transmission Mounts must be used in conjunction with Solid Motor Mounts to prevent breakage of engine block and transmission case due to torsional stress.
http://www.competitionengineering.com/c ... Code=11030
Ok. Makes sense. I thought I could get away with a poly mount. I Appreciate the help.
