CUTLASS COWL HOOD IS FINISHED!
FE3X CLONE
2,714
47
48
Ohio
pencero said:
What's wrong with the ridge? It matches up to the body line on the trunk... I think the ridge makes this cowl hood stand out instead of it being like just any other cowl hood would look...
Every GM cowl hood ever made has had this ridge. It's a throw back to the original Camaro cowl hood. It's just not needed in my opinion, on an Oldsmobile especially when it doesn't match up to any other ridge on the car. The trunk body line is just that, a small body line crease. I think if you wanted to match the trunk line you'd want much less of a ridge and just a small body line crease running up the center of the hood.
DoubleV
2,154
407
83
Medina Ohio
Just because it's a straight line down the center doesn't mean it matches the body line of the trunk lid. They look totally different from one another. The ridge should look like the one on the trunk lid.
You're entitled to your opinion on what you think looks good but I don't see how it 'stands out instead of being like other cowl hood' because it seems every other cowl hood I see has a big ridge so that would make it look like every other cowl hood.
JayPat83
152
16
Knoxville, TN
I like it as is. I have already filled up the indention on my header, ready for a hood like this. What are these things gonna go for?
tobyp
1,708
40
48
Cincinnati, Ohio
here are some renderings of what the new hood will look like. I believe this will look better on the car.
THe hood will retail anywhere from 449-549
tobyp
1,708
40
48
Cincinnati, Ohio
It's gonna set us back a couple months
tobyp
1,708
40
48
Cincinnati, Ohio
Bweavy said:
Months? I thought weeks? Hell the hoods are falling from the sky . :D
cant over promise and under deliver :wink: and this tooling modification is quite extensive
Qdub24
1,796
785
Columbus, GA
I like it and look forward to ordering mine.
I like the new one way better, even smooth would look good imo.
