Cutlass Cruiser resurrection ~ Single Turbo + 4.8L
Nutty Cutty
Apr 30, 2019
66
I powder coat on the side so I got lots of badass colors I can do the parts. I pulled the housing and I'm going to redo it another color. Unsure what yet. Maybe Hot pink or something. I'll post some of my powder coat work.
Nutty Cutty
Apr 30, 2019
66
FB_IMG_1560618903900.jpg FB_IMG_1560619109264.jpg FB_IMG_1560619129430.jpg FB_IMG_1560619056774.jpg FB_IMG_1560619043172.jpg FB_IMG_1560619014646.jpg FB_IMG_1560618966467.jpg FB_IMG_1560618850128.jpg FB_IMG_1560618858634.jpg FB_IMG_1560618882631.jpg FB_IMG_1560618918960.jpg FB_IMG_1560619144407.jpg FB_IMG_1560619212363.jpg
Nutty Cutty
Apr 30, 2019
66
I bought this "LS1 POWER STEERING PUMP" on eBay but I'm not sure it's an actual LS1 PS pump from a Camaro or Vette. I do know that the reservoir isn't included. I think the seller may have listed it falsely on purpose as he started he bought it to do his LS1 swap but didn't need it. I wonder if it's a Lincoln LS ps pump.....
I need a ps pump and reservoir like in the engine pictures as I bought the ICT BILLET kit that positions the accessories in that manner.
Sent from my SM-G965U using Tapatalk
5,711
12,223
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
I didn't see a pic with a ps pump mounted, but here's my setup. I'm also using an ICT bracket kit with alt moved to pass side and LS1 pump. I got my pump with reservoir from Autozone, but I can't comment on the durability yet since I'm not driving.
Nutty Cutty
Apr 30, 2019
66
Doesn't the Vette pump require a remote reservoir?
Also, your original build list mentions a 2 bar MAP sensor - might wnat to rethink that to a GM 3 bar. https://www.robietherobot.com/storm/mapsensor.htm
Why would a genuine GM 2bar MAP not work? I knew enough to stay away from the once claiming to be 2, 3 etc but that looked like a stock 1bar with a sticker on top of it. I paid like $90 for this MAP sensor and everything I read on the ad and packaging shows it to be a Genuine GM 2bar. I will check those stamped numbers though. Thanks.
5,711
12,223
2 bar will stop reading at 14.7 psi. That is the only reason, there os not a quality issue or anything of that nature.
Nutty Cutty
Apr 30, 2019
66
I gotcha. Yes sir I'm aware of the limits. I probably will be limited to that level anyhow since I'll be stuck with only pump 93 and a completely stock 4.8L.
5,711
12,223
I respectfully disagree. A 4.8 with a ‘Stage 2’ cam will take 20 psi before it hits 550 whp. But it will be fun at 14-15.
It’s just that it will be more fun at 20 [emoji12][emoji12]
