I have a problem and need some help, the camino runs good when its warmed up. but when i first start it and until it gets warm it cuts out and backfires threw the carb. any suggestions
the engine is a 267 for all that dont already know. the only mod is a after market open air cleaner.
I HAVE
changed plugs and wires
set the timing
checked all the vacuum lines
set the idle down as low as i can get it without stalling
cleaned the carb
when i bought it the emission tubes were missing off the manifolds and the smog pump was disconnected would any of this be an issue.
I HAVE
set the timing
cleaned the carb
