Diagnosing vibration
My oil pressure also drops to about 20 psi at idle in park warmed up. I don't remember it getting that low so im thinking its either diluted with fuel from running so rich or it has just broken down a little considering its still the 5w30 break in oil. Once I decide on a regulator it will be getting new plugs and some heavier ZDDP enhanced oil. Probably some 50w Valvoline VR1.
does the dipstick smell like gas?
A little yea and the oil seems a lot thinner than normal but it was warmed up and im horrible with identifying that because im so paranoid I automatically assume the worst lol. Either way the car won't run again until I get the new regulator, plugs and oil change. Should be sometime this weekend when I get paid.
The regulator I think im gonna try is a Summit 1.5-25 psi unit. Hopefully I didn't do too much damage to the Quadrajet running the fuel pressure too high for so long. Even my Holley mechanical pump had the pressure between 7-9 psi!
http://www.summitracing.com/parts/sum-220058/overview/
Two questions:
1) where is the regulator mounted?
The reg should be mounted as close as physically possible to the carb to increase the accuracy of your readings. (Mounted on the fenderwell as some guys do is not optimum).
2) what quality and where is the gauge that you're observing your pressures mounted?
The gauge should be mounted directly on the reg on the carb side (post regulated) to know what the actual regulated pressure is at. A quality gauge is a necessity for accurate readings.
I've used the Holley style regs without issues mounted in this manner. I'm not as up to speed on the pressure requirements for Q jets as Holleys, but it boils down to the same thing: the pressure has to be within spec for that carb or you will flood the float bowls and into the body of the carb.
The 7 psi number is the MAX that Holleys should see, and that's running, not static. You should shoot for your pressure to be more like 4 - 5.5 psi running.
There is the possibility your reg is defective, and that's why you're not able to turn down your pressure enough to get below the 7 psi you have, but I suspect it could be an inaccurate gauge/ incorrect reg placement that's compounding your issues.
If I were you, I would replace or warranty the reg and make sure the reg is mounted as I outlined above. The 25 psi reg is not the correct one you should use IMO.
Hope this helps.
Holley "dead head" non return style reg
And an Aeromotive return style both on my car:
My regulator is mounted on the engine with the gauge right off of it between it and the carb.
I should add it is an -8 AN feed line with a -6 AN return line. The tech said that as long as the return line is -6 AN I could run as big of a feed line as I wanted within reason obviously.
Your system looks to be ok, although I'd mount it closer to the carb yet personally. You may run into heat soak issues with it there.
The only other thing I can think of is if the gauge is inaccurate, or there's a problem with the reg itself. Do you have another gauge you can try on there?
Keep us posted on what you find out.
I do have an Autometer gauge I was gonna mount on the cowl scoop but it looked like sh*t so I took it off. I guess I could hook that up and test it. Either way it's running way rich. It burns your eyes and smokes like crazy.
Something else I forgot to add, my fuel pressure drops to about 5 psi when I rev the engine then goes right back to 7 psi when idling.
