i had the slow start issue on my 78,,,and found the rubber fuel hose from top of gas tank was old-dry-cracked open,,,,,,, but a new hose fixed it
Agreed. The rubber lines on top of the tank are always suspect. Look for pin holes under the foam insulator, too.i had the slow start issue on my 78,,,and found the rubber fuel hose from top of gas tank was old-dry-cracked open,,,,,,, but a new hose fixed it
Just curious, as my tank and lines are all original. If this were to be an issue for me in the future, would I smell raw fuel near the rear of the vehicle?Agreed. The rubber lines on top of the tank are always suspect. Look for pin holes under the foam insulator, too.
Correct. My clue was the pump not shutting off and me dumping a gallon on the ground at the gas station. If the rubber is cracked, the fuel pump could suck air.Just curious, as my tank and lines are all original. If this were to be an issue for me in the future, would I smell raw fuel near the rear of the vehicle?
Yeah I’ve never rebuilt a carb so help Will definitely be needed lol any advice will be greatly appreciated.I could change out an accelerator pump on a 2 barrel carb in about 20 minutes. Now that being said, I've done several so I have experience on my side. Using a shop manual and going step by step, it could be done in 45 minutes to an hour if it's your first time. We can help you through it if you want to do it yourself.
Switching to a 4 barrel would require more time and money and may cause more issues you do not have now. If the accelerator pump is all that is wrong, it's a cheap quick fix for you.
