I do a lot of A/C work here in Las Vegas. It was a natural progression of personal curiosity to make my own lines. I was really nervous about how it was going to turn out. Now that it's done I think most mechanically inclined people could do it if they have enough attention to detail. In my signature there is a video I did on general A/C servicing.I don't think anyone has ever done this at home on the Forum before. NICE WORK documenting that it can be done. I particularly like the little clip at the end showing how the axial compressor pump works! On big ships this is what was used to provide 'power steering' for the huge rudder. By tilting a plate, you could change/reverse the stroke of the axial pistons, and return it to idle with the pate centered.
That is a mighty clean looking set-up you have. Are you planning on running hardline to the long runs? if you do, there are weld-on connectors that any specialty A/C shop can do for you. It would keep that clean install looking incredibly clean.I bought the same crimper (really good reviews) to make my lines when the time comes but I am doing a complete system using a trunk mount unit.
I have only made brackets and mounted the compressor so far and working my way back.
It's nice to see that someone else on here has used that tool with good results.
Thanks for the compliment.That is a mighty clean looking set-up you have. Are you planning on running hardline to the long runs? if you do, there are weld-on connectors that any specialty A/C shop can do for you. It would keep that clean install looking incredibly clean.
I am still in the mock up stages for mounting the trunk mount, all of my components are from Vintage Air and I was considering their 5' pre-made hardlines for the frame area but I still am not sure how the lines will actually run but I was also thinking I might be better off running just the Parker standard barrier line because of the distance to keep it better insulated.
I have these lines pictured below leading off the compressor and would like to run braided lines from there to get out of the engine compartment to match the rest but the reviews are not that good for braided lines.
That is a pretty good idea. but why pay $25 to have a professional do it when you could do it yourself for $600.I did a custom install of a Vintage Air unit on a non G-Body. I, too, made up all my own lines. But I don't have the tool. I took mine to a radiator shop that also services AC and he crimped them for me for about $25.
