False. I started at 13 and got my 3000 all in no problem but when bumped to 16 it had great throttle response (in neutral) so i went after getting 16 to work with my total (hence limiter screw). Springs only provided me two options - all in at 2400 (ping city) or all in at 4500.Definitely a ‘no’ imo.
For performance you only need to be concerned about getting the ‘all in’ as soon as your motor can handle it. And getting the correct amount of timing at your all in rpm.
Everything that goes on below the all in rpm is fuel economy and street manners. Tuning those two are completely separate from performance above 3000rpms. And if you want maximum performance with the best possible street manners, then it will take some fiddling with the dizzy and the carb.
I get a sense from your responses that you don’t want to have it idling at 16-20 degrees? Is that so? If yes, then why?
With no limiter screw i am only 3 degrees shy of 16 base and my all in is at 3000 with no pinging (blue line). Its all outlined in the thread. You answered “no” to my question but your explanation is agreeing with it.
So you are saying all in at the lowest possible rpm is best for performance
Bracket is saying higher initial is always best because of better idle and throttle response
I am trying to get both. The graph shows i can get close but with higher initial i am going to also have a higher rpm for my total.
It may come down to WOT vs spirited cruise driving habits. Which to be honest
I am 100% more interested in spirited cruising versus WOT. Gaining throttle response has my attention.
(I mistakenly thought earlier you had suggested running ported vacuum but you did not so i edited that out of this post)
