four turns out is the starting point for the idle mixture screws in the front of the baseplate.
The Mixture solenoid screw - the one that sets the depth of the mixture control solenoid coil in the fuel bowl (aka the lean stop), is initially set with a Thexton 403 tool.
If you dont have the tool, you can measure 1.303" from the base of the primary jet tube (where it enters the brass part of the primary jet) up to the underside of the mix control plunger (holding the plunger all the way down in the solenoid by hand)
Thats the standard start point for tuning
Depending on your carb the rich stop may be automatically set via a small aluminum finger on the screw, or it may be a separate adjustment in the air horn in which case you are looking for about 1/8" travel of the mix solenoid plunger from rich stop to lean stop. Check for this travel once the air horn is installed.
There is anohter thexton tool for setting the proper initial air bleed depth as well.
Then its a matter of hooking up a Dwell meter on 6cyl scale and tuning the air bleed and mix screws
Tune when engine is hot, and try to get a 25-35 dwell (it should vary a little back and forth) va the air bleed. If you cant get it there via the air bleed then you need to adjust the idle mix screws a little bit lean or rich as the case may be and then fine tune again with the air bleed. All the time watching the dwell meter.
Think of the mix screws as BIG adjustment and the air bleed as FINE adjustment.
