Let me ask you if I may. Where do you think timing SHOULD be at on this 10.4:1 LT1
I guess words can only explain so much…. When you asked if i built the motor, to me that means starting with a bare block. I started with a used stock 10.4:1 EFI LT1, leak down and compression tested it, then regasketed it, carb swap, cam etc. “Bolt ons”. So i havent been “told” anything. Everything suggested in this thread has already been checked and checked and checked again. Unfortunately it takes time for jets and rods to arrive. I tried to keep the thread alive in hopes if getting some carb specific info while waiting on shipping. I understand the logic of starting at Point A, developing a baseline and working through the motions. I have already done this. It’s the carb. The merry go round here is the mystery that surrounds the 1407. Its all across the internet. Lots of contradicting info with no apparent solution.Basically you have to know what you have. Find the problem, fix it, and back to happy motoring.
You didn't build the build the engine so you are eat the mercy of what you have been told.
Even I would think that a 750 is too much carb on a 283. I’m glad to hear that it was not. I certainly do not think it’s too much on a 350 despite what the calculator says. Lots of 750/350s out there. Despite all the negativity about Edelbrock. I like the top load design and that the gasket is above the fuel line. If i can get this stumble to disappear it will be an excellent carb.I had an Edelbrock 750 on a mild 289 eons ago and I don't remember it having any bad habits. I did replace it with a shiny new 600 when I got the money, but I really don't recall being overcarbed being a problem in terms of drivability on that one. It was backed by a C6 and installed in a 92 Crown Vic.
78Delta88, I owe you an apology. Im not out of the woods but you are on to something with the timing. First thing. My throttle blades are already closed. I followed your directions to a Tee, and i got highest vaccuum (then retard 1/8”) at a whopping 26 degrees base! Combined with my mechanical 16, this can’t fly! Vac can remained disconnected and plugged. I went easy on it, and it did not stumble.As far as timing concerned I wouldn't get hung up on a setting.
Thanks. Unfortunately I am back at square one. I have been reading about restricting bypass idle air bleed. I suppose it’s worth a shot. The only other thing I can think of, is limit my centrifugal advance even more so i can run like 20 something degrees of base. And continue to use manifold vac for the can. I honestly think Im pretty maxed out. The 1407 has a bad rep. I wonder if it’s time to move on. I’d hate to have the same issues. The carb is great everywhere else.No apologies needed, I understand the frustration.
I started replying earlier, but didn't get to post. Anyway, I didn't take anything said as negative or derogatory.
Try the new jets and rods and see how it goes. It could boil down to just CFM change, mainly smaller primaries and stronger vacuum signal.
On the pumper issue any many don't understand this: even the OEM had problems with off idle transition to acceleration to cruising. So the solution was a pump shot. It's sloppy and many times too rich, but it reduces the bog, so they went with that as a solution.
The Edelbrock carb is a Carter AFB (Aluminum Four Barrel) and it was designed back in the sixties and prevalent with Carter, Ford Autolite/Motorcraft and Mopar's Carter Thermoquad. All very similar and all square bore. GM took different route with Rochester and went Spreadbore.
Yet all had same problem of off idle stumble. This is a lean-out condition that happens when the vehicle is stationary or moving under load, but it is needed to get vehicle to accelerate. OEM solution was to give pump shot of gas. It is sloppy, but it works.
Remember physics?? Friction of Rest is greater than Friction of Motion. When in gear cruising and want to accelerate..., usually no stumble. In motion even if you lean out momentarily, the momentum of rotational force keeps you from experiencing this stumble. When you are sitting still you have no forward momentum and then you get the bog (stumble).
From standing stop or even moving, physics is still Thrust over Weight. On an reciprocal machine like a V8, it boils down to rotational torque. Basically you take ton and half and go from zero to max speed in very little time. So somewhere in there is something that is upsetting that process. So the issue is finding the cause and correcting it.
