Well the car is falling on its face so rpm is very low but i cant get an exact number.When you get the zero vacuum what is the engine RPM?
Just unplug vac advance and drive it ??You need to base line.
For now just do some easy stuff. Unplug line to distributor and plug it off.
Drive it and see if different.
The only issue I have with lowering the timing is, this past spring when i started road testing the car. I started out around 10-12* initial, the distributor out of the box gave something like 24* mechanical at 5000 rpm. I dont remember exactly. But the car was a dog. I am almost certain the off idle bog was still there. I was more focused on other things. Dropping the timing is easy and i will try hopefully tonight. Was raining last night. I certainly18 degrees on 10:1 is too much, then you add full vacuum advance and now, it is way too much. The engine is fighting itself. Don't get too hung up on 36 all in at 3000. That is easy to do with proper setup of springs and weights.
Yours is off idle stumble so get the idle right, then transition to cruise and then acceleration to WOT.
Timing will be smooth all ranges and stumble goes away.
Thanks Nick. Yes I recurved the distributor. Timing is 18 degrees base 16 mechanical all in at 3000-3200. Vac can ran to manifold port. I am not sure how this would cause a stumble on takeoff (which disappears when using about 1/2 mechanical choke - i have a mechanical choke that is cable operated to a choke knob) but runs great everywhere else. Timing keeps coming up in this thread, with the suggestion to retard it even more. I did mention last night that i’d give it a shot but i didn’t get home till late today. I did run the distributor briefly last spring (first road tests) “out of the box” at something like, 12 degrees base, 24 mechanical all in at like 4800+. Ran like a dog. Still had the same stumble.Back to that distributor for a minute or so here. Have you ever popped the cap on it and taken a peek at the weights and springs it came with? This is a very old school subject but back when Sun offered a line of distributor service machines it was possible to take a timer and set it up out of the car using the Sun unit to check and adjust dwell, gap, and advance.
So, I guess my first question ought to be, When you acquired that distributor, did it come with a tuning kit to swap out the weights and springs? Why I ask is that, with a pair of light advance weights and a set of "heavy" advance springs, the timing is not going to advance until almost WOT. If your stumble is not the carburetor but the when and where the advance start to open, then you may need to be looking at keeping the existing weights but changing out the springs to lighter ones so the advance comes in sooner. You could possibly go with a lighter weight set that takes less centrifugual force to open but then you would have to swap in lighter springs to let them move more quickly as well.
There are weight and spring kits available, Moroso for starters, but the thing with them is that they are most valuable for the varying tension of the springs that come in them. The weights and center cam, when compared to the factory versions, are more shapeless and lack the finished shape of what the factory versions possess.
