electric fan
80' bu
Jul 12, 2007
55
Ontario
anyone know of a good dual fan setup that will fit in a gbody? I've heard that an early 90's lumina van had a powerful one that would fit?
Thanks
where did you put the temp sensor? What is a 2 speed Hayden controller worth?
What motor are you running? I've got a 400 so I want to make sure the cooling is adequate
An interesting junkyard option for the temp probe would be the one from a 1988-93 Nissan 240SX. It is a small tube that has the sender screwed into it and you just have to cut the lower radiator hose and install it between the two pieces. That way, you can skip shoving it through the fins. Oddly, the 240SX has an engine driven clutch fan with a second electric fan directly in front of it.
i've got a dual-fan out of a lincoln that fits pretty well. i'm using the derale controller with a sender that threads into the head or intake has has a temp adjustment. works well
LS1 F-Body Fans are a good fit (Probably LT1 as well). You should be able to pick one up for around $100.
89-94 240sx's. 89 was the first year for 240. 94 is a convertable only year. (sorry, I've had a few 240sx's over the years) 😀 The temp probe new for an 89-94 240sx at autozone is 15 bucks or so (probably less). They tend to have temp senders go bad because most of them have over 200k and on the original one. I'd look into a new one insted of the junkyard option, just because they're not expensive.
Just a small heads up 8)
