Teeny dab of blue loctite and 200ftlbs goes a long way.Cool, I learned something new today! Thanks!
I would think that a slip fit might lead to keyway damage, but apparently that's not the case...as long as the retaining bolt remains tight.
He could have his whole build done for that price.
It's ~$100 cheaper. Toss out half the stupid sh*t that doesn't need to be done, it's well under 2k. If Buick 350s were unubtainium and ATK was the SOLE source of them, or at least if they offered "performance" versions, people would be all over it. I have not heard of a single person that bought an old school reman Buick engine, ever. GN, 350, 455, anything. It's just probably slammed together with cheap parts spraypainted black with an *ss and a half camshaft with a warranty. there's just no reason to in this case.Not according to the prices his engine builder gave him, Which is why I posted it
The engine is designed to replace the low compression 72-80 engines, factory compression height deep dish pistons aren't available, so it's safe to surmise what's in it. Either way, it's not good. Someone could get way farther with 2k on an engine they own or a craigslist engine. I've never really understood the point of crate engines tbh.We don't know whats in it so to say that is silly.
Machine shops usually don't like touching anything other than a SBC or a Ford. SBC and fords are what they know best. Anything, especially a buick, that's different usually sets off the "oh boy, here we go" part in their brain I guess.
The '76 rods are heavier and quite a b*tch chunkier by comparison, you will need to use the '76 crank because it's weighted to match. Also, your cast pistons will most likely shatter or crack upon removal. First thing the shop will tell you if you say you want the pistons swapped over is "no garuntees, they'll most likely shatter." Plus, you have to pay for it. So there's the cost of that, and the cost of new pistons. Then they'll want you to balance the whole bottom end to account for the new pistons being of a different weight. It snowballs very quickly. Something along those lines. You don't need to have it bored out. It was running, and from the looks of the piston tops, plugs, and valves and the overall condition, it was running pretty well. All a hone job does is deglaze the cylinder to give a new surface for a new set of rings. Notice how your cylinders are kind of shiny or reflective, a new/freshly honed bore will look like this:Yeah I 100% agree. For roughly the same price I can build the engine I have, with whatever TA cam I want, with TA cam bearings, with a rebuilt TA oil pump, with 10:1 pistons, block cleaned and painted and ready to go.
Let's assume my rods check out and just need cleaned (even if they don't I have the rods from the 76 too, which have cap screws= better rods) (-$100), assume I only need a hone no bore (-$80), assume I don't need the engine decked (-$200), assume the crank only needs magged, cleaned and polished, not custom ground (also have the crank from the '76 and it's in good shape) (-$275), and skip degreeing the cam (-$125).
That saves $780 right there. I want to build this engine. I didn't drive all the way to Indiana for it to take it apart and decide I don't want to put it back together.
