cutlassguy said:do you have a roller cam?
beermonkey9417 said:check yer intake manifold bolts to make sure there tightened down enough. i had the problem when i did my rebuild, or even the carb gasket could be bad or missing. and check the intake for missing NPT fittings or the egr cover for leaks.
cutlassguy said:find the engine code and look it up. is it the original motor?
CHRIS.O said:I don't know what he supposedly was going to replace but I can tell you starting an unhealthy car and idling for a short time to start it again later will kill batteries very quick. Did you ever get a multimeter? Just wondering. If you did you could see if your alternator is working next time it is running. To get it running jump start it if you have some cables. I assume you don't have a battery charger since that douche bag was gonna go charge your battery. But anyway jump start it, should be good enough to get it running.
