The Corvette version is a transaxle. That one won't go in easily.Chillin014 said:Also, which t56's are not easily "compatible" for the swap? I thought I read the c5 corvette t56's had major differences, but I could be wrong.
Your best bet is the LT1 F-body unit used from '93 to '97. The '93 gearbox has a different set of gear ratios and has a slightly lower torque capacity rating but will fit just fine. The flywheels that were used will bolt right up to any one-piece RMS Chevy (non-LS) V8. The LS1 ('98-'02) units can be made to work but I don't have any info on how to do this.
However... It will be a challenge to hook up your speedometer to a T56. Options include using an electric cable driver, an electric speedometer or converting the tailshaft housing to accept a mechanical speedo drive.
Below: A '95 T56 with a speedo drive sourced from Stealth Conversions in my messy garage about six years ago.
