Ok, this is what's happenin now. I have the sender tee'd into a fitting along with my oil pressure line in the front of the block (like a 231), according to my manuals and stuff online, the brown wire coming out of the harness in the firewall near the brake booster is the wire that originally went to the sender. I have that hooked onto one prong and a wire going from the other prong to the choke. The choke/oil light is on steady, and goes off when I unplug the choke. The choke is not opening fully, as if the coil is bad, as if it's not even hooked up. What could be the issue? I have 25psi hot at idle, steadilly rising to 50+ at 5,000rpm. Any input is appreciated. It's gotta be something simple.
