Finally moving my residency to Georgia from Louisiana which means I need to pass the emissions test to register the car here. I took it by just to see how it would do and failed on nox emissions.
Motor is the Olds 307.
First number is reading, second is the allowed
25/25 Test
HC ppm 126 144
CO% 0.06 0.92
NOx ppm 1768 1014
50/15 Test
HC ppm 76 148
CO% 0.04 0.83
NOx ppm 1495 1100
I plan to clean out the EGR valve passageways. I hooked up a vacuum pump and the actuator is still good. Car currently needs to be fed premium to avoid valve rattle on long upgrades (which originally tipped me off to possible EGR problems after reading something from the oldsgmail list.).
I also plan to adjust the mixture control solenoid on the carb now that I know where it should be., since it is running lean (by engine feel and spark plugs). I rebuilt the carb about 2 years ago. Trash was keeping the float valve from seating properly. At the time didn't know how to adjust it beyond using a ruler type measuring device.
I'm also going to change the cat, since my vacuum seems to drop off soon after the engine starts to around 16 inches and I can't find any leaks in the lines. Compression is good, and I don't get any backfire into the exhaust. It also doesn't hesitate when I give it gas from idle like it would when I previously had vacuum leaks.
Is there anything else I should look at or adjust.
Counting the 3 more years until I become emissions exempt.
25/25 Test
HC ppm 126 144
CO% 0.06 0.92
NOx ppm 1768 1014
50/15 Test
HC ppm 76 148
CO% 0.04 0.83
NOx ppm 1495 1100
