this is how I spent my friday night. after work I clocked out then got to work on my car
shaved my antenna hole, tacked in piece of metal, then filled, and grinded out the problem spot on my pillar where I had a stress crack showing thru the epoxy primer, I grinded it out and tried fiberglass filler this time around..after that I blocked my epoxy, had about a dozen low spots, but didn't glaze them was gonna see if the Polyester Primer would fill them. I spot primed the bare metal areas with epoxy then....
...shot 2 coats of the poly-prime...excuse the ghetto mask job, need to buy some plastic sheeting and masking paper
even got the header panel
guide coated then called it a night.
I have a question, the poly prime came with a liquid hardener, but most of it leaked out during shipping. I used what I had to do my 2 coats...I read there are MEK, and MEKP...MEK is a activator and MEKP is a hardener, like what you use with fiberglass...I bought 2 tubes of MEKP but have yet to use them was gonna see if anybody could shed some light and tell me something?
also. I took off the door weatherstripping, my dad mentioned that would be bad for my door hinges, is that correct? I'm tryin to get the outside bodywork done, then take the doors off so I can do the inner doors and jambs, and new weahterstripping installed after but I dont' want to mess up my hinges :|
