damn... i may be worse off than I thought... the only thing i have better than your motor is that its a four bolt main... that does seem oddly low though...
SeeMy355 said:Brick442 said:Sorry if I missed it, what are we talking here, chevy 350?
The carb is not too small--just make sure it is setup correctly. Tune on the dyno if you can.
Torque seems low. At what RPM did you make these numbers? What compression ratio are you at with those heads?
Sorry for the missing information...
I tried to include all the information I thought would be relevant...
Yes, It's a Chevy 350, Chevy 355 actually...
I'll explain how the technician ran the dyno for me...
He told me to gradually increase my RPMs to 3000 and floor it until he waved me off...
My compression ratio should be about 10:9 according my specs...
Brick442 said:SeeMy355 said:Brick442 said:Sorry if I missed it, what are we talking here, chevy 350?
Do you mean the CR is 10.9:1? That may be a little high for that cam and those heads.
2000.malibu.ls said:damn... i may be worse off than I thought... the only thing i have better than your motor is that its a four bolt main... that does seem oddly low though...
patmckinneyracing said:Correct me if I'm wrong, but since its a chassis dyno, wont the gears affect how much horsepower is going to the rear tires. Its more efficient to have a steeper gear if he's looking at having more hp at the rear tire. If he had a high gear then the motor would be loaded up and probably wouldn't be the correct gear for the camshaft. But since he has 373 gears than he should be set.
