Fixing lifters
Antredd77
16
2
How you fix a ticking coming from your left side valve cover lifters of my 305 engine of 85 pontiac grand
19,992
check your oil level first
10,566
14,302
First, a can or two of "lifter quiet". That may clean it and quiet it down. If so then when it does change the oil. If not, time to open the cover and see if the rocker got loose. If so then replace the jam nut and tighten to specs. If not then the lifter is shot and engine must be opened to change it. At that point you might as well change them all.
1,167
2,638
West Virginia
Probably a simple rocker adjustment.
9,617
12,697
My Monte's 305 had a lifter tick so I fixed it by installing a 565 Big Block in it's place,
Reactions: 16 users
500/600
1,167
2,638
West Virginia
Dang. A new cam and lifters is on like $200!
pontiac guy
582
843
Royse City, TX
Turn up the radio. It will run like that for a long time.
