Ok I feel like I have spent a good amount of time searching on this topic, to no avail... I am trying to piece my monte back together but need to address a minor problem (pft minor my A double ss). Looks like I need to replace everything from the tank to the carb. Tank was sitting for six years with half a tank of gas, gas is broken down and now resembles oil more so than gas. Fuel lines look rusted out. On to the question...is there a semi simple way (notice the semi) to replace the fuel lines. I have been told to use Russells twist lok hose from the tank to carb. This seems easy enough, however, I feel that if I take this route I will be rolling the dice to encounter a catastrophe later down the road. I have thought of having new lines bent but this looks near impossible to replace with the body on the frame.
I will be running an electric pump and will be using a bypass regulator, yes I realize its not needed but I have heard more pros than cons in having a return line. Also I would like to utilize the evap line but will live without this one, I guess a vented cap would solve that?
Anyways any help would be much appreciated.
