Is there a company to purchase the tank from that doesn't have this issueNot necessary but will ease in filling up at the pump. This mod is done to stop the pump from cutting off a 100 times while filling up with aftermarket tanks. This aids in venting while pumping gas
I believe this has to do with "vapor recovery" pump nozzles, which used to be required by the feds, but no longer are (except of course here in California, what else). These old-style tanks vent through a channel inside the filler neck, and there are compatibility issues between the way the filler neck venting works and the way various "vapor recovery" nozzles work.
But unless I'm mistaken, none of this should matter if you don't have "vapor recovery" nozzles to contend with.
