fuse block melt down
robert garringer
25
9
bradenton,florida
Well had a problem with all the running lights not working.found the problem it caught fire in a wally world parking lot. Got it repaired but a 10 gauge wire fell out of the fuse block. Its black with a connector on it that looks like a connector that goes on a electric sending unit for a oil press-or a water temp sending unit on the engine. Does any one have a idea where this black 10 gauge wire goes on the fuse block, thank you, Bob
  • Wow
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Glad it didnt burn your entire ride up
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
did the wire come of the engine compartment harness or the light harness? I would take the harnesses off to get a good look at it and you'll probably see where the wire came from. But If you got the repair done by a shop I would take it back to them and I wouldn't touch it.
robert garringer
25
9
bradenton,florida
it burned the wiring harness up and the fuse block is toast it melted the ac duct work cracked the wind shield the carpet is toast it did some damage,plus it burnt my hands and arms up pretty good.But all the wiring is fixed and every thing else is fixed except the wind shield- carpet.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
how did the fire start? I hope you learned to keep a fire extinguisher close, I have one that I carry in my car.
