If it is real heavy try and lighten it up as much as possible. Take off things like air conditioning and what ever you can truly live without. Make sure it is in the best tune possible. Short of that buy a smaller car.
KrisW said:I'd like to suggest something else, as well. What year is your elky? You know there are guys here who have tuned computer quadrajets with decent results. I believe 85 brougham has, and there are lots of guys over on thirdgen.org who have.
All you need is a computer quad, ECM and harness from a 305 to start with and a big cap HEI. You can remove the vacuum advance and run the 7 pin module that allows the computer to run the advance. You can tune it by burning chips with your computer, and it won't cost lots of money. The chips are less than 5 bucks each and it will cost a couple of hundred bucks for the tunerpro stuff to burn chips yourself. It could be a lot of fun and really help you with tuning. It also provides a lock up torque converter circuit. By adding a transmission with a lockup converter you'll get a solid 1 mpg increase. Add tuning to your carb and ignition and I'll bet you'll be happy. You should be able to get all the parts you need for nearly nothing used.
Just something to consider if you are really determined...
KrisW said:Don't you have a vacuum dash pot to pull that linkage piece up on the fast idle cam?
