Re: going to the track sat but another what will she run gue
First things I would do is cheap aftermarket lower control arms. Next an air bag in the passenger-side rear coil to pre-load the suspension. Third if you are not upgrading to a 200-4R get a 2,500 stall for that cam & motor. BTW if your cam is advanced right I would expect it to really come on at 2,500 instead of 3,000. If you could do a lock up converter like the overdrives trans have you could take advantage of even more stall without other issues that you get with the three speed.
Last get a better gear. Assuming you still want to be able to somewhat comfortably afford-ably drive it places (no issues) I would suggest a 3.23 as it provides most of the acceleration benefit but is not over the top as a driver with a non overdrive three speed. Between these I would expect you to drop your 60 foot of 2.76 four or five tenths! A 2.26 would not be out of the way. People usually drop 1.5 tenths in the quarter for every tenth in 60 foot. I would expect to see at least a 13.5 @ 103 with these upgrades probably even considerably lower with slicks.
