Has anyone made their own headliner back board?
fly_25
132
67
I am missing my headliner in my cutlass and I have thought about using those foam gym flooring pads that connect together as the backboard, then using a material to cover when I cut the foam to fit. Haven't done it yet but it's an idea.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
11,963
9,364
Gainesville, Fl
Expanding foam is used in the car audio scene to fill empty areas to reduce rattles, and insulate sound. Typically it's made of 2 parts you mix and then pour into the areas you are trying to fill. I can't put much input into how a headliner would go
I do like the idea of a product that can be poured on rather than sprayed on. I think something with a loose consistency would be more beneficial. I I think by pouring a substance on would give you better workability, if that makes any sense.
1evilregal
3,056
4,355
Greensboro, NC
If you have the existing backing board, you could use it to make the reverse mold with the fiberglass, then you could use the foam to create the new shell,
Longroof79
Oct 14, 2008
11,963
9,364
Gainesville, Fl
Darrin,
I thought about that, but the backside of my existing headliner has a couple repair areas that are a little lumpy, which I feel wouldn't make for a nice mold.. I would think that It would be preferred to start with a board that's smooth and never been repaired. I know that sounds optimistic.
pagrunt
8,744
14,363
Elderton, Pa
This is another reason to miss the original J.C. Whitney. Ages back they used to sell bow style headliner kits to replace the foam board. I still believe the bow style is better than what we have. Wish I bought one back then.
Longroof79
Oct 14, 2008
11,963
9,364
Gainesville, Fl
I think someone still offers a bow style conversion. It would look good if done right.
ck80
Moderator
Moderator
5,499
8,510
JC Whitney. P A W.
Brings back memories, id take them over amazon every time. Good old days.
Reactions: 4 users
1evilregal
3,056
4,355
Greensboro, NC
Darrin,
nice thing about a mold, is you can fill/sand the inside of the buck... I actually have the original backer for my 2dr regal, I patched the cracks/holes with spray adhesive and thinner cereal box cardboard. I guess I've held on to it for all these years hoping to do just this... I had found a better board at a junkyard a few years back (just thinking back, it's been more than 8 years, before I started my current job) and recovered it, and it hangs flat, supported from the back bedroom ceiling ....
