Headers and crossmember
Doug Chahoy
2,565
2,663
I installed my Summit crossmember, correct part number. Then I installed the correct part number Flowmaster header on the passenger side. they don't line up. The crossmember has rounded humps and the exhaust will need at least another inch of clearance on the frame side of the hump I've tried sliding, no good. What next ???
DROLDS84
464
788
Northern Indiana
Does the header flange reach the crossmember? It shouldn't.when you take the car to get the exhaust installed they will probably just need to tweak it a little for good clearance.Exhaust work is not an exact science,a good installer should be able to make it work for you.
7,989
18,702
I wish my car was together. I have the G Force crossmember and am wondering if it would line up better.
Andebe
241
256
Indiana
My G-Force was marked for a wrong way and right way application,possible its bassakwards? :)
Doug Chahoy
2,565
2,663
The header ends about 4 inches shy of the crossmember. It would need an S fitting to aim the pipes under the crossmember. And I'm doing my own exhaust work.
20,397
you are not the first to have a problem with flowtech headers. I would heat up the tubes on the header to tweak it so the pipe is lined up with the hump.
7,989
18,702
He bought the Flowmaster headers. They are ceramic coated stainless and were expensive. I would fab a different transmission crossmember before I modified the headers.
Doug,
Could you get a local exhaust shop to make you an 'S' Pipe? I have a place local that does mandrel bent stainless work.
Jim hopper
Mar 29, 2017
97
88
Doug,
I went to summit and bought s style collectors and it solved my problem
Jim hopper
Mar 29, 2017
97
88
The s-bend collectors at summit that worked for me are part # hed-18804 u just need to trim them for youer app thay come long because I had the same problem no problems all gone
