brettlaage03 said:
I don't know what is keeping them on. The headlight switch was changed because I installed a Grand Prix dash in my Monte Carlo and it still won't let the lights turn off. What could this be? Door switches. I would think if they were bad the lights wouldn't come on. IDK It started the day I bought the thing a few months ago.
Brett,
You may have to systematically disconnect things until you locate the culprit. Have you disconnected the door switches? Something sounds like it's shorting somewhere. Perhaps a bad light switch? Gotta love those electrical gremlins. :?
...or you can pull fuses one at a time until you find the circuit that's giving you fits. Then troubleshoot that circuit.
I'm not an expert by any stretch, but I think that's where I'd start.
Was the problem there when you bought the car initially, or when you did the dash swap?
Sorry I jumped the gun a little here. The problem is with your interior lights. If i'm not mistaken, the interior lights are on the same circuit with the door switches. Are the under dash lights on as well? Again, it could also be your light switch. It's a process of elimination.
