Help new clear coat scratches so easy
Rus
283
858
Queensbury, NY
I just had my hood painted on my car with a base, clear. The body shop gave me the car and I have our stored in my garage. I noticed when I got it home, it had what appeared to be dust all over. I brushed off a spot on the paint and it scratched. I then used rinse water over it and let it dry. I put car cover on it and now, it has more scratches. Is this the way clear coat is or is something wrong with the paint job?-
ck80
Moderator
Moderator
5,743
9,122
Leaving aside the quality issues, you never put a cover on a freshly painted car. Paint is "soft" and subject to scratches until it fully cures which, although it varies by type used, is at least days or longer from when it's sprayed.
There are also "recommendations" about use of soaps, limitations on waiting a month or more before using any wax or sealer, etc
pagrunt
9,167
15,346
Elderton, Pa
What temp is the garage being kept at? Colder temps will make the drying/"out gassing" of the clear take longer which will allow more scratches & blems.
Rktpwrd
Builder of Cool Shjt
4,168
23,918
Calgary, Alberta, Canada
As the guys have said, the paint is fresh and soft and hasn’t had enough time to cure yet. The worst thing you can do with a fresh paint job is “wipe” dust off. It should be strictly hands off for at least a week, even possibly as long as a month until you’re sure it’s fully cured.
As said, a lot of it will have to do with the ambient air temperature it’s being stored at, cooler temperatures will extend and prolong the curing time. How soft the clear is will also largely depend on how the shop did the job, if they had a bake cycle that they ran the car through when they were done, the clear will be a lot harder and closer to a full cure than if they just allowed it to air dry at room temperature.
Reactions: 5 users
Rus
283
858
Queensbury, NY
I keep garage at 62.
ck80
Moderator
Moderator
5,743
9,122
This made me cringe.
Agreed.
Had the hood replaced under warranty on one of the 2016 mustangs. (Galvanic corrosion defect) Told the wife after she picked it up you don't touch it, don't wipe it, don't "rest" a purse or anything on it. She had a bird crap on it which is corrosive in its own right and I popped a hole in 2 water bottles to blast it under pressure and wash the residue off before damage.
I'd taught her about that issue, so she was conflicted about removal versus not touching anything.
Lesson to be learned: it is difficult, but occasionally a woman CAN be trained.
ck80
Moderator
Moderator
5,743
9,122
Please provide detailed information manual for said training.
It is both proprietary and confidential. However, motorheadmike also expressed prior interest in a coaching/lesson based system. Perhaps a program could be offered on a discount basis for early subscribers...
  • Clever
