RITTER said:NAPA also offers these in our brass fitting bin. If there is already a compression sleeve smashed on the nylon oil line, you are going to want to cut that off and put a new one on. Its not really a good idea to reuse those after their original seal has been broken. They cost like $0.05, so its completely worth it to just replace it, instead of leaking oil all over and then replacing it.RockSS said:Go to the hardware store and buy a 90 degree fitting they have all kinds of adapter in the plumming section ... What your looking for is a 90 degree 1/8 pipe tread on one end and 1/8 compression fitting on the other ... you just slip the nut over your tubing then the compression ring then tighten the ring is tapered so when you tighten it it crimps on to the tube making it not leak ... that being said you do not have to crank it as tight as you can ... 😀
So, cut off that section. Take the piece to NAPA (or whichever store you go to) to be 100% certain that you have the correct size. Just let them know that you need a compression union to 1/8 male NPT fitting![]()
Its not a nylon line it is metal and it is not a compression fitting currently.
