How do i fix this??
I was going to ask Michigan door, but you answered that already . Southern Michigan or do you mean Toledo? Get another door not worth the time and electricity to weld. I bet the other side is just as good?
No, not Toledo, Southwest Michigan right between Kalamazoo and Battle Creek. Actually, the other door is perfect, just the inner drivers door.
The not so short answer to your question is, it depends. I went through the exercise of trying to reconstruct that lower shelf on a M/Carlo inner door skin several years ago and found that I had to make the replacement in several sections and piece them in. Based on your pictures, you would have to come all the way up and onto the flat lands to find good solid un-rusted metal. If the outer skin is still intact, it can be done, but I agree with others on this thread who bring up the valid points of time and money. To them I would add some type of metal break or stretcher/shrinker due to the curves and angles. The other thing you would have to replicate is the holes for the plastic tees that hold the lower door gasket in place. They are not drilled at random; the pattern for them matches the locations for the tees in the gasket. If the inner skin parts are available still they would be the easiest way to go. Only complication to that is that Good Mark may still be shut down and not producing components due to COVid. I have been waiting on an outer door skin from them for almost a year.
Reactions: Steve 82 Elly
When I replaced my doors I actually sold my rusty ones to someone that saw them sitting in my garage when they were here buying something else they said they were going to cut out the rust and then fiberglass it, I had already stripped them of their mirrors and power windows and locks so I was happy to take their money.
If you've got a mig and a little patience you could repair them. Here's a guy I've been following for a few months now on YouTube. He used to own his own restoration shop up in Canada so he has seen his fair share of rust. He makes it look easy but I've used some of his tips in my work and it's made a huge difference. Here's the link to his door repair video. Hope this helps.
IMO.... which is whatever. Id would cut the rust out and fiberglass a new panel. Fiber glass is cheap.
