Here is the proper disc/drum proportioning valve that GM came up with in brass to replace the iron original that was in our cars. GM parts catalog list in group 4.690,GM p/n 25509419 / AC Delco p/n 172-1353. This installed on my frame with stainless lines.I told myself I wouldn't comment on your threads any more because you ask for advise and if it isn't what you want to here ignore it. Dito Rktpwrd great words of wisdom. You don't want to put a $40.00 line lock on because it's too much (which I'm very happy your not) and yet you want to do a ZO6 upgrade $$$. I run the stock brake system in my Regal with good parts and have never had a problem. Engineers have spent a lot of time in development of the proportioning valve and I'm not going to second guess them. Take Rktpwrd's advice - I second it.
It is also used on '80's B bodies with the bigger front brakes (11" rotors). This is in my opinion of the right part for the repair.
Inline Tube sells these in disc/drum & 4 wheel disc, for different models. They could have what is needed that don't require extra add on parts.
