my bad you are correct. I always get that back asswards LOL you think Id get it after all these year in my businessI don't want to muddy the thread with disagreement, but I think you may have stated this backwards. "Normally" is at rest and not energized.
https://www.galco.com/comp/prod/relay.htm
If we're both referring to the diagram on page 3, that's normally open. If we're talking about a different diagram I'll have to go back and look.
If the brown wire is neither grounded or shorted to power, it's actually a normally closed relay -- which is good because then 565 doesn't need to do anything. It could also be a NO relay that's just stuck in the closed position. Either way, if power goes through it to the clutch, that's just like having no relay and if we all pretend it isn't there, the system will function like an "old" car.
It's a NO relay so it needs to be grounded to close and provide 12v to clutch on green/blk wire 966
sorry for the confusion
