If it doesn't have the computer, how would I delete the emissions?
just curious actually if you dont mind elaborating what all would be different in the block?obviously an oil return would need to be drilled but not really sure of the other differencesThe turbo blocks are different from the NA blocks and the 3.8 blocks vary slightly from year to year.
Blocks are stronger, some have more bolts in the block for the oil pan (85 and below have less than 86+) and yes an oil return. An N/A block can be made into a turbo engine easilly, but it will never hold upto like 20 psi all the time as the turbo blocks would. The carbed NA models are designated LD5 and the turbos are LC2 staring in 1986 when they got intercoolers.just curious actually if you dont mind elaborating what all would be different in the block?obviously an oil return would need to be drilled but not really sure of the other differences
