I recently swapped my 231 to a 350 Chevrolet and the parts I used were: Engine mounts (on frame) - 1987 Chevy MC SS, I didn't change the front springs, I used the serpentine kit from Summit, which is mostly aluminum, the weight is almost the same. I also used a trans crossmember from Summit, for the 700R4. I had to visit the salvage yard for the radiator "lid", the V6 shroud obviously will not fit. Dual electric fans and a R134 conversion rounded it out. 3" cut from the driveshaft. Note: a 200C and a 700R4 use the same driveshaft yoke. This setup is only a stand-in, the Regal is getting a LS4 with a 6L90 or maybe one of the new GM 10 speeds I've been hearing about, time will tell. Happy swapping.
