Little late to this conversation, but I'll relay my experience as I have done both swaps into my 81 GP. I swapped a nice 455 with a higher lift version of an 068 cam, RA aftermarket manifolds, Pypes 2.5" duals, modified Q-jet, and T400 with 2500 stall converter. At the time of the swap i hadn't changed the rear 7.5 with its abysmal gearing, but that was next on the list. Anyway, even with the crap gearing the 455 was awesome. To be clear, I have always hopped up Pontiacs and that's where my bias lies. At the same time I wanted to do an LS swap into a project. Then, along came someone looking for a 455 that was already done and was offering good money, so I made the call to sell him the 455/T400 package out of the 81 and that financed my 6.0L swap, to a degree anyway. As already noted, there is a cost difference between the two options, and once the financial dust had settled I had significantly more invested into the 6.0/4L60e than in the 455/T400. It's also more complicated on the electrical side so prepare to go through that learning curve if you keep the EFI. So the takeaway? The 455 was predictably torquey and wonderful. The nose of the car felt marginally heavier than the Chev 265 it replaced, but not to cause any weird handing by any means. In fact, the only reason I say that is because the car felt noticeably lighter in the front with the 6.0. The only mods to the 6.0 I put in were a GM Hot Cam, Holley cast exhaust manifolds, and a good tune. The 6.0 is possibly the "quickest" engine I have ever owned, but that's based solely on my butt dyno. It is VERY responsive and just keeps pulling and pulling. I am very happy with my LS and am glad I did the swap, but it came with lessons. I know people online are proclaiming to do these swaps for $1.49, but they are either extremely lucky, or perhaps a little loose with their details. Either engine will make you very happy and it's sounds more like a case of being spoiled for choice. From a bang-for-the-buck ROI, it sounds like, for you personally, that the 428 is the way to go, all things being equal. The LS is a great choice as well for many reasons, but will challenge you a bit more on install and in the pocket book. Sorry if all of that muddies the waters more than it helps! Best of luck with your choice. IMO, you win either way.
