Interior Paint code 62D
Toadstool
20
58
13
Lockeford CA
Hi guys I blew it I should of left my dash alone but could not help it. I was finishing up my shifter project and thought I would touch up my glove box door with sem camel 15173.
It worked well on my steering column and door panel(I guess they were a little faded)my interior paint code is 62 d which I believe is dark camel. What do you guys suggest for me to find the correct paint. 1978 oldsmobile cutlass.
Thank you for your help
9,180
15,385
SEM does have a mix service that they will make you a batch of near factory match. Keep in mind with age nothing will be a 100% perfect match some other members have had a good experiance with their color match. But as a PPG guy I would really recommend PPG's One Choice system. PPG's codes for your Dark Camel Tan is 24542 for semi-gloss & 24530 for flat. A semi-gloss/low gloss would work on the door,
mikester
2,926
3,713
Small town NY
Thats correct. SEM offers a free color matching service. Ive had them match a few colors for me and they do close to a perfect match. I even sent them a rear door panel from my wagon. The womans name that does it is Ann Zolle. She has a real talent at custom matches.
Did you spray the inside of the door too ? If not, take the door apart and send it to her. She can match it to the untouched color inside of the door under the black. I also sent her a gray glovebox door from a Regal to get a match and it was 100%. She does it as soon as she gets the piece.
She can give you the formula but Ive been buying the Color Coat directly from them since they can test the color before they send everything back to you so you'll know it will match.
Toadstool
20
58
13
Lockeford CA
Thank you so much for all your help you two.
I guess I'm color blind should of tested the color first before painting that door. My shifter floor console is off to.
Thanks again.
