A good factory floor would definitely be nice to have. I don't think I really need all of it, but it would certainly make things easier. Removing all the braces is what is really a pain. I'm not sure exactly how much I'll end up removing but it's pretty likely I'll wind up removing a brace. Good to know the Sherman floor comes with the inner rocker just in case I can't get ahold of a factory pan.
I'm going to try to rebuild the inner rocker in a less complicated way than GM did. I have to take a closer look at that patch panel that was welded in from underneath. If you look at my last picture, you can see the green fiberglass filler where the edges of the patch were dressed. On the side forward of the fiberglass filler is the patch panel, on the side rearward is the body mount. I believe the body mount itself is okay.
