hey all, my name is Blake, and I have a 1984 Monte Carlo ss with a targetmaster 2pc rms 350 that was installed in 1986 under warranty, and the original th350c.
At some point in time somebody installed a 3.73 motive gear into the open carrier (and didn’t change the speedo gear), but with the tires I have on it, the car was turning 3500 rpms at like 65 mph.
I picked up the car this year for my birthday, and it’s my third Monte.
My original one had a Mike lis spec vortec headed 350 in it, originally with a 700r4, then later with an lt1 t56. I had that car from the time I was 15, until I went to grad school when I was 25. I ended up having to part it out to buy books for school.
I had a second one I should never have bought that I put a 5.3 in and hooked up to the stock th2004r, which it toastedin 2 weeks under normal driving, then I got married,it went to the bottom of the priority list, and Then the body rotted away. I ended up selling it for a song to a body guy that wanted a father son project for his son.
this newest one has a little rust on the drivers side (which I will head off at the pass ASAP) and some frame rot, which I will address by replacing the frame.
I was originally planning on canibalizing a 1986 corvette I had to bring this thing into a more modern state of being.
the 350 that’s in it is on borrowed time, and between what it is leaking and what it is consuming, I’m having to put 2-3 quarts of oil in it a week. Between that and the lack of overdrive, this Monte isn’t ready for prime time as a reliable daily driver.
then I stumbled upon grandprix454’s build thread. I loved everything about it. I’m going to make a few executive decisions on some stuff, but that swap accomplishes all of my goals with a few modifications. I’ll end up with a 1pc rms roller cam 4 bolt block. I already ordered an engine harness and a computer tune from Howell efi so I will be able to control the trans and maintain the sfi. I am running an electric fan, a Bosch 044 fuel pump, and the donor truck had a helper pusher fan, a very nice bar and plate auxiliary transmission cooler, it is set up for an oil cooler, which I have to figure out, as my Monte radiator doesn’t have provisions for an in rad oil cooler. Factory serpentine belt assembly, upgraded alternator, upgraded style a/c compressor, and the strongest automatic overdrive transmission ever to come from the general.
I ordered a set of cheapie mid length chevelle headers from speedway, 3” collectors with o2 bungs, and an egr delete plate. If this stuff arrives by Saturday, the next update should be the motor in the car ready for final hookups.
