I haven't looked at any of the codes or numbers other than making sure the title was correct, but I'll definitely look into that. I didn't even open the trunk until I got her home, and I found the missing "Cutlass Supreme" badges as well as the "Brougham" badges and some extra center caps. The missing door strips were in the passenger seat.Rally wheels and gauges, nice options f41 perhaps
Hmm, I've never heard that bit of information before. I haven't ran the numbers but the seller told me it's a 305 and it's definitely a Chevy. Everything appears stock as well. And although I'm not fluent in Quadrajet this engine does indeed have a 4 barrel. I actually like that it has the Quad, as it's a fine carburetor that doesn't get enough love. Now I have a reason to learn about them.Just a consideration here, but I was under the impression that 305 Chevys only came with 2 bbl carbs until 1980. If that is the case, you have a 2 bbl, and this kit number crosses with a Quadrajet 4 bbl. I could be wrong.
I found the correct info. There was an LG4 option (4 bbl) on the 78 Cutlass, but NOT for California.Hmm, I've never heard that bit of information before. I haven't ran the numbers but the seller told me it's a 305 and it's definitely a Chevy. Everything appears stock as well. And although I'm not fluent in Quadrajet this engine does indeed have a 4 barrel. I actually like that it has the Quad, as it's a fine carburetor that doesn't get enough love. Now I have a reason to learn about them.
No kidding? That's really cool, and another sweet option that makes this car even more special. I might have to go check the trim tag since you're already here...I found the correct info. There was an LG4 option (4 bbl) on the 78 Cutlass, but NOT for California.
Trim tag won't tell you about the engine. But your VIN should. The 5th spot in the VIN should be either U or H. Yours should be an H (4 bbl 305). The U is for the 2 bbl version.No kidding? That's really cool, and another sweet option that makes this car even more special. I might have to go check the trim tag since you're already here...
