Correct. I think the mis-info cames from one the bolt holes aren't used (if it was the bolt would go through the head - I think it is the passenger-side).Doober said:You heard wrong The LS motor has the same bolt pattern as a traditional SBC, the issue comes into play with flywheel-to-torque converter measurements, you need a spacer or special torque converter for everything to work correctly.
jae said:Correct. I think the mis-info cames from one the bolt holes aren't used (if it was the bolt would go through the head - I think it is the passenger-side).Doober said:You heard wrong The LS motor has the same bolt pattern as a traditional SBC, the issue comes into play with flywheel-to-torque converter measurements, you need a spacer or special torque converter for everything to work correctly.
But have a question on the trans - did you get another crossmember, move it since the pads are in different locations between the 200-4R and the 350?
Yup! Sorry I haven't posted much, but I've been busy with work and family. I have been working on the car a little here and there, though nothing really worth a pic yet.pmoore4321 said:Any updates?
