Serial # D 2961-13 Spec Card# 24966813
Part # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
Core C54-11HH CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE
Grind # LS1 13158 /13159 HR113.0
DURATION @ .050 INTAKE 227 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 230 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3560 EXHAUST 1.70
VALVE LIFT INTAKE .605 LOBE LIFT EXHAUST .3580
VALVE LIFT EXHAUST .608 LOBE SEPARATION 113.0
DURATION .006 INTAKE C/L 110.0
TAPPET LIFT INTAKE 278 CAM ADVANCE 3
TAPPET LIFT EXHAUST 282 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 3 JOURNAL DIAMETER STD 2.165
VALVE OPEN EXHAUST 51 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 43 DEPARTMENT P
VALVE CLOSED EXHAUST 1- SPC INSTR FOR CUSTOMER
SERIAL # ONLY ON CAM
Kwik_Cutty88 said:What are your plans for exhaust, I've got some LS3 Camaro manifolds for sale.
LS1GN said:The timing chain and gears ended up being a real pain in the butt for me - it was the crank sprocket that did NOT want to come off.
